Enabled Property
The Enabled property indicates whether the favorites are enabled.
    [bool=] SiteKiosk.Favorites.Enabled
    The following example determines whether favorites are enabled and shows it in an alert window.
    alert(SiteKiosk.Favorites.Enabled);
