SaveOnClose Property
The SaveOnClose property indicates whether the favorites should be saved when SiteKiosk is closed.
[bool=] SiteKiosk.Favorites.SaveOnClose
Boolean value that retrieves the state.
The following example determines whether the favorites should be saved when SiteKiosk is closed and shows it in an alert window.
alert(SiteKiosk.Favorites.SaveOnClose);
