Delete Method
The Delete method deletes the job.
[bool=] SiteKiosk.Printer.Printers.Item(index1).Jobs.Item(index2).
Delete()
Returns a Boolean value that indicates whether the function succeeded.
The following example deletes the first print job of the first available printer if it is waiting for a command.
if (SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).IsWaiting)
SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Delete();
