Status Property
The Status property contains the job status.
    [long=] SiteKiosk.Printer.Printers.Item(index1).Jobs.Item(index2).
            Status
    Long value that retrieves the status.
    StatusName should be checked prior to this member and, if StatusName is NULL, the status is defined by a combination of the following values:
    JOB_STATUS_PAUSED = 0x00000001
    JOB_STATUS_ERROR = 0x00000002
    JOB_STATUS_DELETING = 0x00000004
    JOB_STATUS_SPOOLING = 0x00000008
    JOB_STATUS_PRINTING = 0x00000010
    JOB_STATUS_OFFLINE = 0x00000020
    JOB_STATUS_PAPEROUT = 0x00000040
    JOB_STATUS_PRINTED = 0x00000080
    JOB_STATUS_DELETED = 0x00000100
    JOB_STATUS_BLOCKED_DEVQ = 0x00000200
    JOB_STATUS_USER_INTERVENTION = 0x00000400
    JOB_STATUS_RESTART = 0x00000800
    JOB_STATUS_COMPLETE = 0x00001000
    See JOB_INFO_2 (MSDN) for further information.
    The following example displays the status of the first available print job of the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Status);
