StatusName Property
The StatusName property contains the description of the print job status.
StatusName
String that retrieves the description.
This member should be checked prior to Status and, if StatusName is NULL, the status is defined by the contents of the Status member.
See JOB_INFO_2 (MSDN) for further information.
The following example displays the description of the first available print job's status of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).StatusName);
