Enabled Property
The Enabled property indicates if the language is enabled.
[bool=] SiteKioskWindow.SkinLanguages.Item(index).Enabled
Boolean value that retrieves if the language is enabled.
The following example shows the enabled status of the first language in an alert window.
alert(SiteKioskWindow.SkinLanguages.Item(1).Enabled);
