LanguageInfo Object
The LanguageInfo object contains information about the different skin languages.
    The following table lists the members provided by the LanguageInfo object.
    Members
    Properties Description
    Enabled If the language is enabled.
    EnglishName English name for the language.
    LangID ID of the language.
    Name Name of the language.
    This object is returned by the Item method. Use the LanguageInfo object to determine the name or ID of the language.
    The following example shows the name of the first available language in an alert window.
    alert(SiteKioskWindow.SkinLanguages.Item(1).Name);
