Name Property
The Name property contains the name of the language.
[str=] SiteKioskWindow.SkinLanguages.Item(index).Name
String that retrieves the name of the language.
The following example shows the name of the first available language in an alert window.
alert(SiteKioskWindow.SkinLanguages.Item(1).Name);
