IsKeyboardSwitchingEnabled Property
The IsKeyboardSwitchingEnabled property indicates whether the touchscreen keyboard layout can be switched.
[bool=] SiteKiosk.LocaleManager.IsKeyboardSwitchingEnabled
The following example determines whether the touchscreen keyboard layout can be switched and shows it in an alert window.
alert(SiteKiosk.LocaleManager.IsKeyboardSwitchingEnabled);
SiteKiosk v6.6 (and later versions).
