LocaleManager Object
The LocaleManager object represents the system language.
The following table lists the members provided by the LocaleManager object.
This object is available through the main object SiteKiosk.
Use the LocaleManager object to read and set the system language and to read the default language.
The following example reads the LangID property and shows it in an alert window.
alert(SiteKiosk.LocaleManager.LangID);
