OnHotKeyPressed Event
Fires when a hotkey has been pressed.
SiteKiosk.LocaleManager.OnHotKeyPressed = handler
name |
String that contains the name of the hotkey. |
Hotkeys can be defined in the hotkey xml file. The path of this file is saved in the registry (HKEY_LOCAL_MACHINE\SOFTWARE\PROVISIO\SiteKiosk\HotKeyFile). This event fires for hotkeys of the type 17 only.
Example:
<hotkeys>
<hotkey type='17' vkey='91' sound='0'>
<name>Windows key</name>
</hotkey>
</hotkeys>
The following example shows an alert window when a hotkey has been pressed.
SiteKiosk.LocaleManager.OnHotKeyPressed = OnHotKeyPressed;
function OnHotKeyPressed(name)
alert(name);
SiteKiosk v6.6 (and later versions).
