OnKeyboardLayoutChange Event
Fires when the touchscreen keyboard layout changed.
SiteKiosk.LocaleManager.OnKeyboardLayoutChange = handler
handle |
Long value that contains the handle of the new layout. |
The following example shows the name of the touchscreen keyboard layout when it has been changed.
SiteKiosk.LocaleManager.OnKeyboardLayoutChange = OnKBLayoutChange;
function OnKBLayoutChange(handle)
KBLayouts = SiteKiosk.LocaleManager.KeyboardLayouts;
for (i = 1; i <= KBLayouts.Count; i++)
if (KBLayouts.Item(i).Handle == handle)
alert(KBLayouts.Item(i).DisplayName);
SiteKiosk v6.6 (and later versions).
