OnLanguageChange Event
Fires when a user changes the SiteKiosk language.
SiteKiosk.LocaleManager.OnLanguageChange = handler
langid |
Long value that contains the language ID. |
The following example shows the current language ID when it has been changed.
<div id="id_langid"></div>
SiteKiosk.LocaleManager.OnLanguageChange = OnLanguageChange;
function OnLanguageChange(langid)
id_langid.innerHTML = "Current language: " + langid;
