Set Method
The Set method creates or updates a new template variable by key and value.
    SiteKiosk.Plugins("SiteCash").Set(key, value)
    key String that specifies the key of the template variable.
    value String that specifies the the value of the template variable.
    The following example creates a new template variable called $(RemainingSurftime).
    var SiteCash = SiteKiosk.Plugins('SiteCash');
    SiteCash.Macromap.Set("RemainingSurftime", SiteCash.RemainingSurftime);
