Macromap Object
The Macromap object allows to specify template variables and expand input strings with their current values.
The following table lists the members provided by the Macromap object.
Methods |
Description |
Expand |
Expands current template text with template variables. |
Get |
Gets a template variables value. |
Set |
Defines a new or updates an existing template variable. |
This object has some predefined auto-updating template variables:
$(Date) current date
$(Time) current time
$(ComputerName) terminal name
$(ComputerGuid) computers unique identifier
$(SenderEmail) senders email address
$(Sales) accumulated sales since session start
$(Balance) sessions current balance
$(CurrencySymbol) symbol of current currency
The
ReceiptSettings Object provides a
TemplateText Property which takes
advantage of them.
The following example shows how to format text with the help of the Macromap object.
var SiteCash = SiteKiosk.Plugins('SiteCash');
if (SiteCash.Enabled)
var Macromap = SiteCash.Macromap;
Macromap.Set("RemainingSurftime", SiteCash.RemainingSurftime);
alert(Macromap.Expand("You currently have a balance"
+ " of $(CurrencySymbol) $(Balance), allowing you"
+ " to surf $(RemainingSurftime) seconds."));
