BalanceAvail Property
The BalanceAvail property indicates if the balance can be modified.
[bool=] SiteKiosk.Multimedia.BalanceAvail
Boolean value that retrieves whether the balance can be modified.
The following example determines if the balance can be modified and shows it in an alert window.
alert(SiteKiosk.Multimedia.BalanceAvail);
