Multimedia Object
The Multimedia object controls the soundcard settings.
    This object is available through the main object SiteKiosk. Use the Multimedia object to read or change the soundcard settings.
    The following example determines if a soundcard is available and shows it in an alert window.
    alert(SiteKiosk.Multimedia.SoundCardPresent);
