BassAvail Property
The BassAvail property indicates if the bass value can be modified.
[bool=] SiteKiosk.Multimedia.BassAvail
Boolean value that retrieves whether the bass value can be modified.
The following example determines if the bass value can be modified and shows it in an alert window.
alert(SiteKiosk.Multimedia.BassAvail);
