DecreaseRecVolume Method
The DecreaseRecVolume method decreases the recording volume by a specified amount.
    SiteKiosk.Multimedia.DecreaseRecVolume(amount)
    amount Float value between 0 and 1 that specifies the
    recording volume decrease.
    The following example decreases the recording volume by 10 percent.
    SiteKiosk.Multimedia.DecreaseRecVolume(0.1);
