DecreaseVolume Method
The DecreaseVolume method decreases the volume by a specified amount.
    SiteKiosk.Multimedia.DecreaseVolume(amount)
    amount Float value between 0 and 1 that specifies the
    volume decrease.
    The following example decreases the volume by 10 percent.
    SiteKiosk.Multimedia.DecreaseVolume(0.1);
