IncreaseMicVolume Method
The IncreaseMicVolume method increases the microphone volume by a specified amount.
SiteKiosk.Multimedia.IncreaseMicVolume(amount)
amount |
Float value between 0 and 1 that specifies the
microphone volume increase. |
The following example increases the microphone volume by 10 percent.
SiteKiosk.Multimedia.IncreaseMicVolume(0.1);
