IncreaseRecVolume Method
The IncreaseRecVolume method increases the recording volume by a specified amount.
    SiteKiosk.Multimedia.IncreaseRecVolume(amount)
    amount Float value between 0 and 1 that specifies the
    recording volume increase.
    The following example increases the recording volume by 10 percent.
    SiteKiosk.Multimedia.IncreaseRecVolume(0.1);
