IncreaseVolume Method
The IncreaseVolume method increases the volume by a specified amount.
    SiteKiosk.Multimedia.IncreaseVolume(amount)
    amount Float value between 0 and 1 that specifies the
    volume increase.
    The following example increases the volume by 10 percent.
    SiteKiosk.Multimedia.IncreaseVolume(0.1);
