MicMuted Property
The MicMuted property indicates if the microphone mixer is currently muted.
[bool=] SiteKiosk.Multimedia.MicMuted
Boolean value that specifies or retrieves whether the microphone mixer is muted.
Before using this property the first time, check the MicMutedAvail property to determine
if the microphone mixer can be muted.
The following example determines if the microphone mixer is currently muted and shows it in an alert window.
alert(SiteKiosk.Multimedia.MicMuted);
