MicVolumeAvail Property
The MicVolumeAvail property indicates if the microphone volume can be modified.
    [bool=] SiteKiosk.Multimedia.MicVolumeAvail
    Boolean value that retrieves whether
    The following example determines if the microphone volume can be modified and shows it in an alert window.
    alert(SiteKiosk.Multimedia.MicVolumeAvail);
