Muted Property
The Muted property indicates if the mixer is currently muted.
[bool=] SiteKiosk.Multimedia.Muted
Boolean value that specifies or retrieves whether the mixer is muted.
Before using this property the first time, check the MutedAvail property to determine
if the mixer can be muted.
The following example determines if the mixer is currently muted and shows it in an alert window.
alert(SiteKiosk.Multimedia.Muted);
