OnMicMuteChanged Event
Fires when the microphone mixer has been muted or unmuted.
    SiteKiosk.Keyboard.OnMicMuteChanged = handler
    muted Boolean value that indicates if
    the microphone mixer is muted.
    The following example shows the muted status when it has been changed.
    SiteKiosk.Keyboard.OnMicMuteChanged = OnMicMuteChanged;
    function OnMicMuteChanged(muted)
       alert(muted);
