OnMicVolumeChanged Event
Fires when the microphone volume has been changed.
    SiteKiosk.Keyboard.OnMicVolumeChanged = handler
    micvolume Float value value between 0 and 1 that
    retrieves the current microphone volume.
    The following example shows the current microphone volume when it has been changed.
    SiteKiosk.Keyboard.OnMicVolumeChanged = OnMicVolumeChanged;
    function OnMicVolumeChanged(micvolume)
       alert(micvolume);
