OnMuteChanged Event
Fires when the mixer has been muted or unmuted.
    SiteKiosk.Keyboard.OnMuteChanged = handler
    muted Boolean value that indicates if
    the mixer is muted.
    The following example shows the muted status when it has been changed.
    SiteKiosk.Keyboard.OnMuteChanged = OnMuteChanged;
    function OnMuteChanged(muted)
       alert(muted);
