OnRecMuteChanged Event
Fires when the recoding mixer has been muted or unmuted.
    SiteKiosk.Keyboard.OnRecMuteChanged = handler
    muted Boolean value that indicates if
    the recording mixer is muted.
    The following example shows the muted status when it has been changed.
    SiteKiosk.Keyboard.OnRecMuteChanged = OnRecMuteChanged;
    function OnRecMuteChanged(muted)
       alert(muted);
