OnRecVolumeChanged Event
Fires when the recording volume has been changed.
SiteKiosk.Keyboard.OnRecVolumeChanged = handler
recvolume |
Float value value between 0 and 1 that retrieves
the current recording volume. |
The following example shows the current recording volume when it has been changed.
SiteKiosk.Keyboard.OnRecVolumeChanged = OnRecVolumeChanged;
function OnRecVolumeChanged(recvolume)
alert(recvolume);
