OnVolumeChanged Event
Fires when the volume has been changed.
SiteKiosk.Keyboard.OnVolumeChanged = handler
volume |
Float value value between 0 and 1 that
retrieves the current volume. |
The following example shows the current volume when it has been changed.
SiteKiosk.Keyboard.OnVolumeChanged = OnVolumeChanged;
function OnVolumeChanged(volume)
alert(volume);
