RecBalance Property
The RecBalance property contains the current recording balance.
    [flt=] SiteKiosk.Multimedia.RecBalance
    Float value between 0 and 1 that specifies
    or retrieves the recording balance.
    The following example shows the current recording balance in an alert window.
    alert(SiteKiosk.Multimedia.RecBalance);
