RecMuted Property
The RecMuted property indicates if the recording mixer is currently muted.
    [bool=] SiteKiosk.Multimedia.RecMuted
    Boolean value that specifies or retrieves whether
    the recording mixer is muted.
    Before using this property the first time, check the RecMutedAvail property to determine
    if the recording mixer can be muted.
    The following example determines if the recording mixer is currently muted and shows it in an alert window.
    alert(SiteKiosk.Multimedia.RecMuted);
