RecVolumeAvail Property
The RecVolumeAvail property indicates if the recording volume can be modified.
[bool=] SiteKiosk.Multimedia.RecVolumeAvail
Boolean value that retrieves whether the recording volume can be modified.
The following example determines if the recording volume can be modified and shows it in an alert window.
alert(SiteKiosk.Multimedia.RecVolumeAvail);
