SoundCardPresent Property
The SoundCardPresent property indicates if a soundcard is available.
[bool=] SiteKiosk.Multimedia.SoundCardPresent
Boolean value that retrieves whether a soundcard is available.
The following example determines if a soundcard is available and shows it in an alert window.
alert(SiteKiosk.Multimedia.SoundCardPresent);
