TrebleAvail Property
The TrebleAvail property indicates if the treble value can be modified.
[bool=] SiteKiosk.Multimedia.TrebleAvail
Boolean value that retrieves whether the treble value can be modified.
The following example determines if the treble value can be modified and shows it in an alert window.
alert(SiteKiosk.Multimedia.TrebleAvail);
