VolumeAvail Property
The VolumeAvail property indicates if the volume can be modified.
[bool=] SiteKiosk.Multimedia.VolumeAvail
Boolean value that retrieves whether the volume can be modified.
The following example determines if the volume can be modified and shows it in an alert window.
alert(SiteKiosk.Multimedia.VolumeAvail);
