DisplayNotifyWindow Property
The DisplayNotifyWindow property indicates if the notification area has been enabled in the SiteKiosk configuration.
[bool=] SiteKiosk.WindowList.NotificationArea.DisplayNotifyWindow
Boolean value that retrieves the visibility status.
The following example determines if the notification area is enabled and shows it in an alert window.
alert(SiteKiosk.WindowList.NotificationArea.DisplayNotifyWindow);
