NotificationArea Collection
The NotificationArea collection provides information about the taskbar notification area.
The following table lists the members provided by the NotificationArea collection.
Properties |
Description |
Count |
The number of currently existing notify icons. |
DisplayNotifyWindow |
If the notification area is enabled. |
DisplayOnlySiteKioskApps |
If the notification area should only show programs that have been started by SiteKiosk. |
VisibleIconCount |
The number of currently visible notify icons. |
Methods |
Description |
Item |
Returns one item of the collection. |
Events |
Description |
OnInserted |
Fires when a new icon has been added. |
OnModified |
Fires when an existing icon has been modified. |
OnRemoved |
Fires when an icon has been removed. |
OnSetFocus |
Fires when the focus has been set. |
This collection is available through the object WindowList.
Use the NotificationArea collection to receive information about the taskbar notification area or to change the appearance and behaviour of notification icons.
The following example shows the number of currently existing notify icons.
alert(SiteKiosk.WindowList.NotificationArea.Count);
