DisplayOnlySiteKioskApps Property
The DisplayOnlySiteKioskApps property indicates if the notification area should only show programs that have been started by SiteKiosk.
[bool=] SiteKiosk.WindowList.NotificationArea.DisplayOnlySiteKioskApps
The following example determines if the notification area should only show programs that have been started by SiteKiosk and shows it in an alert window.
alert(SiteKiosk.WindowList.NotificationArea.DisplayOnlySiteKioskApps);
