OnModified Event
Fires when an existing icon has been modified.
SiteKiosk.WindowList.NotificationArea.OnModified = handler
The following example shows an alert window when an existing icon is modified.
SiteKiosk.WindowList.NotificationArea.OnModified = OnModified;
function OnModified(iconinfo)
alert("Existing icon has been modified: " + iconinfo.ID);
