OnSetFocus Event
Fires when the focus has been set to the tray window.
SiteKiosk.WindowList.NotificationArea.OnSetFocus = handler
The following example shows an alert window when the focus has been set to the tray window.
SiteKiosk.WindowList.NotificationArea.OnSetFocus = OnSetFocus;
function OnSetFocus()
alert("Tray window has been focused");
