Info Property
The Info property contains the text of the balloon.
    [str=] SiteKiosk.WindowList.NotificationArea.Item(index).Info
    String that retrieves the text of the balloon.
    A balloon containing information text will be displayed under Windows 2000/XP if balloon tip has been enabled in the SiteKiosk configuration.
    The following example shows the balloon text of the first existing icon in an alert window.
    alert(SiteKiosk.WindowList.NotificationArea.Item(1).Info);
