InfoTitle Property
The InfoTitle property contains the title of the balloon.
    [str=] SiteKiosk.WindowList.NotificationArea.Item(index).InfoTitle
    String that retrieves the title of the balloon.
    A balloon containing information text will be displayed under Windows 2000/XP if balloon tip has been enabled in the SiteKiosk configuration.
    The following example shows the balloon title of the first existing icon in an alert window.
    alert(SiteKiosk.WindowList.NotificationArea.Item(1).InfoTitle);
