SiteKioskApp Property
The SiteKioskApp property indicates if the program has been defined as an external application in the SiteKiosk configuration.
    [bool=] SiteKiosk.WindowList.NotificationArea.Item(index).SiteKioskApp
    The following example determines if the program of the first existing icon has been defined an an external application in the SiteKiosk configuration.
    alert(SiteKiosk.WindowList.NotificationArea.Item(1).SiteKioskApp);
