Timeout Property
The Timeout property contains the timeout period of the balloon.
[dword=] SiteKiosk.WindowList.NotificationArea.Item(index).Timeout
DWORD value that retrieves the timeout period.
A balloon containing information text will be displayed under Windows 2000/XP if balloon tip has been enabled in the SiteKiosk configuration.
The following example shows the balloon timeout period of the first existing icon.
alert(SiteKiosk.WindowList.NotificationArea.Item(1).Timeout);
