Tip Property
The Tip property contains the text of the tooltip.
[str=] SiteKiosk.WindowList.NotificationArea.Item(index).Tip
String that retrieves the text of the tooltip.
The following example shows the tooltip text of the first existing icon.
alert(SiteKiosk.WindowList.NotificationArea.Item(1).Tip);
