BlockingEnabled Property
The BlockingEnabled property indicates whether popups will be blocked.
    SiteKiosk.SiteKioskUI.PopupManager.BlockingEnabled [=bool]
    Boolean value that specifies or retrieves the enabled status.
    The following example enables popup blocking.
    SiteKiosk.SiteKioskUI.PopupManager.BlockingEnabled = true;
