PopupManager Object
The PopupManager object controls the popup management.
The following table lists the members provided by the PopupManager object.
Property |
Description |
BlockingEnabled |
Whether popup blocking is enabled. |
Methods |
Description |
ExcludePages |
Excludes the specified pages from popup blocking. |
Events |
Description |
OnPopup |
Fires when a popup is about to be displayed. |
OnPopupBlocked |
Fires when a popup has been blocked. |
This object is available through the SiteKioskUI object.
Use the PopupManager object to change the way SiteKiosk blocks popups.
The following example determines whether popup blocking is enabled and displays it in an alert window.
alert(SiteKiosk.SiteKioskUI.PopupManager.BlockingEnabled);
